[GRASS-dev] WinGRASS71svn using Windows shell (not bourne shell) thogh MSYS is installed
Helmut Kudrnovsky hellik at web.de
Fri Oct 24 15:15:27 PDT 2014
Glynn Clements wrote
> Helmut Kudrnovsky wrote:
>> AFAIR years ago there was some issue with the g.mkfontcap run during
>> installation which needed msys in %path%.
> g.mkfontcap is a binary executable; I have no idea why it would need
> MSys.
> Glynn Clements <
> glynn at .plus
> grass-dev mailing list
> grass-dev at .osgeo
> http://lists.osgeo.org/mailman/listinfo/grass-dev
 If Freetype is not installed, the font list will be limited to the set of
Hershey stroke fonts supplied with GRASS
it's from the manual.
AFAIR it was needed for this freetype step. it has to be tested.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/WinGRASS71svn-using-Windows-shell-not-bourne-shell-thogh-MSYS-is-installed-tp5168808p5169491.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
