[GRASS-dev] Improving the G_calloc: unable to allocate xx bytes of memory message?
Markus Neteler
neteler at osgeo.org
Mon Oct 27 04:27:21 PDT 2014
On Sat, Oct 25, 2014 at 12:13 AM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
>> > r.basin map=map at Elevation prefix=o coordinates=-71.10394196,43.9865230801
>> > threshold=19005 dir=C:\\Users\\Andrea\\Basins
>> > I get:
>> > v.to.rast complete.
>> > All in RAM calculation...
>> > Reading raster map <o_map_drainage_e>...
>> > Calculating basins using vector point map...
>> > Current region rows: 21612, cols: 21612
>> > ERROR: G_calloc: unable to allocate 21612 * 4 bytes of memory at io.c:41
>> Question: is there a way to also communicate in which *command* the
>> memory allocation occurred, i.e. improve the error message?
> Why should allocation errors be different to any other error?
That's true.
> For the case of scripts, it may suffice to fix run_command() etc so
> that they terminate (or raise an exception) if the module returns a
> non-zero exit status. If the error message is immedately followed by
> "error executing <command>", it should remove most of the ambiguity.
Yes, that would be a perfect solution to be implemented.
>> We have 9 files called "io.c" in GRASS 7.
>> Ideal would be something like:
>> ERROR: G_calloc: unable to allocate 21612 * 4 bytes of memory at r.thin/io.c:41
>> or
>> ERROR: r.thin: G_calloc: unable to allocate 21612 * 4 bytes of memory
>> at r.thin/io.c:41
>> Not sure how to implement that in lib/gis/alloc.c
> alloc.c is the wrong place. If you want errors to be traceable, the
> module name should be included for *all* errors by G_fatal_error (and
> possibly others).
> Also, I wouldn't suggest using module/file.c, because that will be
> inaccurate (and thus misleading) if the caller is part of a library.
> If we just want the complete filename in allocation errors, we can
> modify the compiler switches to include $(RELDIR) as per the attached
> patch. Similarly for use of __FILE__ in the iostream headers.
Ok, I tried that patch but I don't manage to trigger it.
GRASS 7.1.svn (nc_spm_08_grass7):~ > g.region rast=elevation -p res=0.01
projection: 99 (Lambert Conformal Conic)
zone: 0
datum: nad83
ellipsoid: a=6378137 es=0.006694380022900787
north: 228500
south: 215000
west: 630000
east: 645000
nsres: 0.01
ewres: 0.01
rows: 1350000
cols: 1500000
cells: 2025000000000
GRASS 7.1.svn (nc_spm_08_grass7):~ > r.cost roadsmajor output=bla
start_coordinates=637500.000000,221750.000000
WARNING: segment zero_fill(): Unable to write (No such file or directory)
WARNING: Could not write segment file
ERROR: Can not create temporary file
Yet a bit unhelpful :-) It comes from lib/segment/format.c but I
didn't manage to improve that.
Markus
