[GRASS-dev] Improving the G_calloc: unable to allocate xx bytes of memory message?
Markus Neteler
neteler at osgeo.org
Mon Oct 27 09:12:08 PDT 2014
On Mon, Oct 27, 2014 at 4:33 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
>> Ok, I tried that patch but I don't manage to trigger it.
>> GRASS 7.1.svn (nc_spm_08_grass7):~ > g.region rast=elevation -p res=0.01
>> rows: 1350000
>> cols: 1500000
>> cells: 2025000000000
> That's 1.8 * 2^40 cells; at 24 bytes/cell, it would be 44 TiB.
Yes, I tried to do some extreme computing. But GRASS/Linux resisted
easily as you point out below.
>> GRASS 7.1.svn (nc_spm_08_grass7):~ > r.cost roadsmajor output=bla
>> start_coordinates=637500.000000,221750.000000
>> WARNING: segment zero_fill(): Unable to write (No such file or directory)
> So it's not trying to allocate 44 TiB of RAM, it's trying to create a
> 44 TiB segment file, which fails for other reasons.
> You'll need to find something which actually allocates RAM rather than
> a temporary file. Try "r.proj memory=..."; this allocates the cache
> memory before creating any temporary file.
>> WARNING: Could not write segment file
>> ERROR: Can not create temporary file
OK, no success with r.proj (to crash it) but this one triggered the new message:
GRASS 7.1.svn (nc_spm_08_grass7):~ > g.region rast=roadsmajor res=0.1 -p
projection: 99 (Lambert Conformal Conic)
zone: 0
datum: nad83
ellipsoid: a=6378137 es=0.006694380022900787
north: 228500
south: 215000
west: 630000
east: 645000
nsres: 0.1
ewres: 0.1
rows: 135000
cols: 150000
cells: 20250000000
GRASS 7.1.svn (nc_spm_08_grass7):~ > v.to.rast roadsmajor out=test
use=attr attrcol=PROPYEAR memory=3000000 --o
WARNING: No areas selected from vector map <roadsmajor>
Current region rows: 135000, cols: 150000
ERROR: G_calloc: unable to allocate 18446744072484715136 * 4 bytes of
memory at vector/v.to.rast/raster.c:84
... only, it does not return to command line (have to use CTRL-C).
>> Yet a bit unhelpful :-) It comes from lib/segment/format.c but I
>> didn't manage to improve that.
> Specifically:
> if (write(fd, buf, n) != n) {
> G_warning("segment zero_fill(): Unable to write (%s)", strerror(errno));
> ENOENT ("No such file or directory") isn't a valid error code for
> write(). But errno is only set if write() returns -1, so it's likely
> that write() returned a short count rather than failing and the errno
> value is left over from a previous system call (sucessful calls don't
> reset errno to zero). In all probability, the next call to write()
> would have failed due to ENOSPC, EDQUOT, or EFBIG (or raised SIGXFSZ
> if RLIMIT_FSIZE is being exceeded).
I see and now darkly remember something about discussion in this list
about clearing the previous error state.
Markus
