[GRASS-dev] Unable to open vector map && g.list
Vaclav Petras
wenzeslaus at gmail.com
Mon Oct 27 19:25:05 PDT 2014
On Mon, Oct 27, 2014 at 4:04 PM, Martin Landa <landa.martin at gmail.com>
wrote:
> Hi,
> 2014-10-27 20:58 GMT+01:00 Martin Landa <landa.martin at gmail.com>:
> > $ v.info staty_definicnibod
> > ERROR: Unable to open vector map <staty_definicnibod at PERMANENT>
> strangely the map is possible to remove.
> $ g.remove type=vect name=staty_definicnibod -f
> Removing vector <staty_definicnibod>
Can you please try to write some tests for this? (Something trivial like
this should be enough.)
I was not completely following but here is what could be related from past
days:
http://trac.osgeo.org/grass/changeset/62389
http://osgeo-org.1560.x6.nabble.com/v-overlay-handles-mapname-mapset-in-a-wrong-way-td5162363.html
http://lists.osgeo.org/pipermail/grass-dev/2014-October/071362.html
http://trac.osgeo.org/grass/ticket/2437#comment:18
http://trac.osgeo.org/grass/ticket/2437#comment:23
> Martin
> Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa *
> http://www.gismentors.eu/mentors/landa
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141027/e115d755/attachment.html>
