[GRASS-dev] Fwd: New Defects reported by Coverity Scan for grass
Anna Petrášová kratochanna at gmail.com
Wed Oct 29 07:46:13 PDT 2014
On Wed, Oct 29, 2014 at 9:31 AM, Markus Neteler <neteler at osgeo.org> wrote:
> Hi,
> I have uploaded the current trunk (r62476), some improvements achieved!
>     Analysis Summary:
>        New defects found: 4
>        Defects eliminated: 19
> Below the 4 newly introduced issues, hoping for comments/fixes.
> Markus
> The results are available at http://scan.coverity.com/projects/1038
> ---------- Forwarded message ----------
> From:  <scan-admin at coverity.com>
> Date: Wed, Oct 29, 2014 at 2:19 PM
> Subject: New Defects reported by Coverity Scan for grass
> To: neteler at osgeo.org
> Hi,
> Please find the latest report on new defect(s) introduced to grass
> found with Coverity Scan.
> 4 new defect(s) introduced to grass found with Coverity Scan.
> 19 defect(s), reported by Coverity Scan earlier, were marked fixed in
> the recent build analyzed by Coverity Scan.
> New defect(s) Reported-by: Coverity Scan
> Showing 4 of 4 defect(s)
> ** CID 1249942:  Resource leak  (RESOURCE_LEAK)
> /raster/r.viewshed/grass.cpp: 661 in save_grid_to_GRASS(grid_ *, char
> *, int, outputMode_)()
should be fixed in r62477,8
> ** CID 1249941:  Untrusted value as argument  (TAINTED_SCALAR)
> ** CID 1249940:  Untrusted value as argument  (TAINTED_SCALAR)
> ** CID 1249939:  Uninitialized pointer read  (UNINIT)
> /ps/ps.map/ps_vpoints.c: 272 in PS_vpoints_plot()
> should be fixed in r62479,r62480
> ________________________________________________________________________________________________________
> *** CID 1249942:  Resource leak  (RESOURCE_LEAK)
> 655             }                       /* for j */
> 656             Rast_put_row(outfd, outrast, type);
> 657         }                           /* for i */
> 658         G_percent(1, 1, 1);
> 659
> 660         Rast_close(outfd);
> >>>     Variable "outrast" going out of scope leaks the storage it points
> to.
> 661         return;
> 662     }
> 663
> 664
> 665
> 666
> *** CID 1249941:  Untrusted value as argument  (TAINTED_SCALAR)
> /lib/segment/open.c: 89 in Segment_open()
> 83         close(SEG->fd);
> 84         if (-1 == (SEG->fd = open(SEG->fname, 2))) {
> 85      unlink(SEG->fname);
> 86      G_warning(_("Unable to re-open segment file"));
> 87      return -4;
> 88         }
> >>>     Passing tainted variable "SEG->srows" to a tainted sink.
> 89         if (0 > (ret = Segment_init(SEG, SEG->fd, nseg))) {
> 90      close(SEG->fd);
> 91      unlink(SEG->fname);
> 92      if (ret == -1) {
> 93          G_warning(_("Could not read segment file"));
> 94          return -5;
> *** CID 1249940:  Untrusted value as argument  (TAINTED_SCALAR)
> /lib/segment/init.c: 78 in Segment_init()
> 72      || !read_off_t(fd, &SEG->ncols)
> 73      || !read_int(fd, &SEG->srows)
> 74      || !read_int(fd, &SEG->scols)
> 75      || !read_int(fd, &SEG->len))
> 76      return -1;
> 77
> 78         return seg_setup(SEG);
> 79     }
> 80
> 81
> 82     static int read_int(int fd, int *n)
> 83     {
> *** CID 1249939:  Uninitialized pointer read  (UNINIT)
> 266                 }
> 267             }
> 268
> 269             /* draw the icon */
> 270             if ((vector.layer[vec].epstype == 0) ||
> 271                 (vector.layer[vec].epstype == 2 && !eps_exist)) {
> >>>     Using uninitialized value "Symb".
> 272                 if (Symb != NULL) {
> 273                     symbol_draw(sname, x, y, size, rotate,
> 274                                 vector.layer[vec].width);
> 275                 }
> 276             }
> 277         }                           /* for (line) */
> 278
> 279         fprintf(PS.fp, "\n");
> 280         return 0;
> To view the defects in Coverity Scan visit,
> http://scan.coverity.com/projects/1038?tab=overview
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141029/7479fed0/attachment-0001.html>
