[GRASS-dev] Dead code
Markus Neteler
neteler at osgeo.org
Thu Oct 30 03:45:17 PDT 2014
On Thu, Oct 30, 2014 at 11:38 AM, Pietro <peter.zamb at gmail.com> wrote:
> On Thu, Oct 30, 2014 at 10:49 AM, Markus Neteler wrote:
>> On Thu, Oct 30, 2014 at 8:40 AM, Glynn Clements wrote:
>>> Are the replacements sufficient? g.setproj had a lot of logic for
>>> dealing with the relationships between various parameters. Has that
>>> been incorporated into the GUI? Is it unnecessary? Or does everyone
>>> just use EPSG codes now?
>> No, EPSG codes do not represent all. Especially since we still need to
>> update the CSV files included in lib/proj/ which are pretty dated now.
>> See README.txt therein for a better approach.
> If the connection is available
... internet connection is not necessarily available.
> why not retrieve these information directly from the web?
> something like:
> In [1]: import urllib2
> In [2]: def get_epsg_wkt(epsg):
> ...: response =
> urllib2.urlopen('http://epsg.io/{epsg}.wkt'.format(epsg=epsg))
> ...: return response.read()
> In [3]: print(get_epsg_wkt(3003))
> PROJCS["Monte Mario / Italy zone 1",GEOGCS["Monte
> Mario",DATUM["Monte_Mario",SPHEROID["International
> 1924",6378388,297,AUTHORITY["EPSG","7022"]],TOWGS84[-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68],AUTHORITY["EPSG","6265"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4265"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",9],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",1500000],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["X",EAST],AXIS["Y",NORTH],AUTHORITY["EPSG","3003"]]
This delivers only one of several TOWGS84 parameters.
In the location manager is a selection dialog with respect to the
actual EPSG code and the datums stored in
lib/gis/datum.table
lib/gis/datumtransform.table
Markus
