[GRASS-dev] wxpython 3 and errors in grass
Michael Barton Michael.Barton at asu.edu
Thu Oct 30 12:29:50 PDT 2014
At least for me, it is possible to have multiple versions of wx installed. The important thing is which you use when you compile GRASS—determined by the path to wx_config
Michael
______________________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
Tempe, AZ  85287-2402
USA
voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax:          480-965-7671(SHESC), 480-727-0709 (CSDC)
www:  http://csdc.asu.edu, http://shesc.asu.edu
http://www.public.asu.edu/~cmbarton
On Oct 30, 2014, at 10:57 AM, <grass-dev-request at lists.osgeo.org<mailto:grass-dev-request at lists.osgeo.org>> <grass-dev-request at lists.osgeo.org<mailto:grass-dev-request at lists.osgeo.org>> wrote:
From: Moritz Lennert <mlennert at club.worldonline.be<mailto:mlennert at club.worldonline.be>>
Subject: [GRASS-dev] wxpython 3 and errors in grass
Date: October 30, 2014 at 10:57:46 AM MST
To: grass-dev <grass-dev at lists.osgeo.org<mailto:grass-dev at lists.osgeo.org>>
I've recently started to see errors when trying to run gui tools such as the interactive color definition or when I try to add a legend to the map composer, and the windows do not open. The traceback is below.
I imagine that this is linked to the fact that I have now wx 3 installed next to wx 2. But what is the solution ?
Moritz
 File
"/data/home/mlennert/SRC/GRASS/grass64_release/dist.x86_64
-unknown-linux-gnu/etc/wxpython/lmgr/frame.py", line 1182,
in RulesCmd
ctable = RasterColorTable(self)
 File
-unknown-linux-gnu/etc/wxpython/modules/colorrules.py", line
752, in __init__
title = _('Create new color table for raster map'),
**kwargs)
 File
334, in __init__
self._doLayout()
 File
780, in _doLayout
bodySizer = self._createBody(parent = self.panel)
 File
469, in _createBody
bodySizer.AddGrowableCol(2)
 File "/usr/lib/python2.7/dist-
packages/wx-3.0-gtk2/wx/_core.py", line 15364, in
AddGrowableCol
return _core_.FlexGridSizer_AddGrowableCol(*args, **kwargs)
wx._core
PyAssertionError
C++ assertion "!m_cols || idx < (size_t)m_cols" failed at
../src/common/sizer.cpp(1980) in AddGrowableCol(): invalid
column index
grass-dev mailing list
http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141030/72991263/attachment-0001.html>
