[GRASS-dev] wxpython 3 and errors in grass
Anna Petrášová
kratochanna at gmail.com
Thu Oct 30 18:34:15 PDT 2014
On Thu, Oct 30, 2014 at 1:57 PM, Moritz Lennert <
mlennert at club.worldonline.be> wrote:
> Hi,
> I've recently started to see errors when trying to run gui tools such as
> the interactive color definition or when I try to add a legend to the map
> composer, and the windows do not open. The traceback is below.
> I imagine that this is linked to the fact that I have now wx 3 installed
> next to wx 2. But what is the solution ?
It is totally fine to use wxPython 3 on Linux, so the solution is to fix
the bugs. We actually need someone testing it with the newer version. Most
bugs are quite easy to fix, so please report them to me directly offlist
and I will let you know if I can fix it immediately or if you should create
a ticket in case of more complicated things.
wxPython on Mac is a different story, it's much more problematic, because
the 32-bit version is difficult compile with and the 64-bit version is
buggy. No idea about Windows.
I fixed the colorrules.py, could you send me some more info about the other
problem?
Anna
> Moritz
> Traceback (most recent call last):
> File
> "/data/home/mlennert/SRC/GRASS/grass64_release/dist.x86_64
> -unknown-linux-gnu/etc/wxpython/lmgr/frame.py", line 1182,
> in RulesCmd
> ctable = RasterColorTable(self)
> File
> -unknown-linux-gnu/etc/wxpython/modules/colorrules.py", line
> 752, in __init__
> title = _('Create new color table for raster map'),
> **kwargs)
> File
> 334, in __init__
> self._doLayout()
> File
> 780, in _doLayout
> bodySizer = self._createBody(parent = self.panel)
> File
> 469, in _createBody
> bodySizer.AddGrowableCol(2)
> File "/usr/lib/python2.7/dist-
> packages/wx-3.0-gtk2/wx/_core.py", line 15364, in
> AddGrowableCol
> return _core_.FlexGridSizer_AddGrowableCol(*args, **kwargs)
> wx._core
> PyAssertionError
> C++ assertion "!m_cols || idx < (size_t)m_cols" failed at
> ../src/common/sizer.cpp(1980) in AddGrowableCol(): invalid
> column index
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141030/c976f4dc/attachment-0001.html>
