[GRASS-dev] [GRASS GIS] #2466: r.param.scale slow on Windows when there is no data in raster
GRASS GIS trac at osgeo.org
Fri Oct 31 07:54:35 PDT 2014
 Reporter:  annakrat            |       Owner:  grass-dev@…
     Type:  defect              |      Status:  new
 Priority:  normal              |   Milestone:  7.0.0
Component:  Raster              |     Version:  unspecified
 Keywords:  r.param.scale, nan  |    Platform:  MSWindows 8
      Cpu:  Unspecified         |
 When I run r.param.scale on Windows with raster map with a lot of no data,
 the computation is significantly slower (90 s on Ubuntu, 50 min on
 Windows). r.param.scale doesn't propagate nulls. I read somewhere that
 computing with nan can be slower on some architectures, could this be the
 reason?
 I attached a patch to propagate nans. I also realized that at one point
 during preprocessing, there are large numbers computed (especially with
 big cell size and high window size), so I thought double would be more
 appropriate.
 If there are no objection, I would commit it to test it on Windows.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2466>
