[GRASS-dev] G7 blockers call
Anna Petrášová kratochanna at gmail.com
Wed Sep 3 20:34:00 PDT 2014
On Wed, Sep 3, 2014 at 6:32 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
> wenzeslaus wrote
> > On Sat, Aug 23, 2014 at 3:35 AM, Martin Landa <
> > landa.martin@
> > wrote:
> >> > So far I had two students reporting the problem with MSVCR.71.dll
> >> missing - I have added the link to the
> >> > WinGRASS_errors wiki to the course webpage so I hope that will help.
> >> Checking "Important Microsoft runtime libraries" in the installer
> >> should solve this problem [1].
> >> I think this issue is discussed also somewhere else since I remember
> > writing this somewhere already. Anyway, at least for the record, checking
> > the check box does not help. Getting through the 2 other suggestion on
> > wiki
> > does not help either. But doing the steps from the installer manually
> > works
> > (the third suggestion). This was the case on two (or more) computers
> > already.mention Martin
> >> [1]
> http://grasswiki.osgeo.org/wiki/WinGRASS_errors#The_GRASS_GIS_.28winGRASS.29_exits_immediately_after_I_start_it.21
> > grass-dev mailing list
> > grass-dev at .osgeo
> > http://lists.osgeo.org/mailman/listinfo/grass-dev
> are you installing winGRASS standalone with admin rights (e.g. right click
> run as admin)?
> can you test it with and without "run as admin" on these win machines?
I remember trying both options without success.
Anna
> can you also test at which manually step mentioned in the wiki winGRASS is
> working/not working.
> the OSGeo4W-package is unfortunately a moving window...
> best regards
> Helmut
> http://osgeo-org.1560.x6.nabble.com/G7-blockers-call-tp5157820p5159968.html
> Sent from the Grass - Dev mailing list archive at Nabble.com.
> grass-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140903/f31be8af/attachment.html>
