[GRASS-dev] Tests down to 58% (from 81%)
Vaclav Petras
wenzeslaus at gmail.com
Thu Sep 4 19:44:41 PDT 2014
On Thu, Sep 4, 2014 at 11:18 AM, Markus Neteler <neteler at osgeo.org> wrote:
> Since you track "success" or "failed", could you please add an
> additional column to retain the last rev number of "success" (maybe as
> link to trac changeset)? Then one could easily navigate to the
> subsequent changes.
The problem is that I do not track anything specific. I just generate the
HTML report and that's it. There might be some solution using key-value
files and searching through test report directory tree but the ultimate
solution is to store test result (values for report) in database and then
generate report from the database (so that current and previous values are
accessible in the same way and also better organized).
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140904/fd7a52ad/attachment.html>
