[GRASS-dev] [GRASS-SVN] r60596 - grass/trunk/vector/v.in.ogr
Anna Petrášová
kratochanna at gmail.com
Sat Sep 6 10:45:00 PDT 2014
On Sat, Sep 6, 2014 at 12:59 PM, Huidae Cho <grass4u at gmail.com> wrote:
> Hi,
> Glad to hear that you solved the issue. Even before this revision,
> strcmp(db_get_default_driver_name(), "pg") was there... Anyway, I think
> initializing a database connection in the location wizard is the right way
> to fix it.
I might have looked at wrong revision. Still, if the default db connection
is uninitialized, v.in.ogr would crash. I don't know if there is some other
case where this could happen, probably not.
Anna
> Thanks.
> Huidae
> On Sat, Sep 6, 2014 at 9:25 AM, Anna Petrášová <kratochanna at gmail.com>
> wrote:
>> On Fri, Sep 5, 2014 at 11:54 PM, Anna Petrášová <kratochanna at gmail.com>
>> wrote:
>>> On Fri, May 30, 2014 at 12:46 AM, <svn_grass at osgeo.org> wrote:
>>>> Author: hcho
>>>> Date: 2014-05-29 21:46:55 -0700 (Thu, 29 May 2014)
>>>> New Revision: 60596
>>>> Modified:
>>>> grass/trunk/vector/v.in.ogr/main.c
>>>> Log:
>>>> v.in.ogr: fallback datetime type for pg and dbf drivers
>>>> Modified: grass/trunk/vector/v.in.ogr/main.c
>>>> --- grass/trunk/vector/v.in.ogr/main.c 2014-05-30 04:01:53 UTC (rev
>>>> 60595)
>>>> +++ grass/trunk/vector/v.in.ogr/main.c 2014-05-30 04:46:55 UTC (rev
>>>> 60596)
>>>> @@ -103,6 +103,8 @@
>>>> int OFTIntegerListlength;
>>>> char *dsn;
>>>> + const char *driver_name;
>>>> + char *datetime_type;
>>>> char *output;
>>>> char **layer_names; /* names of layers to be
>>>> imported */
>>>> int *layers; /* layer indexes */
>>>> @@ -336,9 +338,18 @@
>>>> G_fatal_error(_("Required parameter <%s> not set"),
>>>> param.dsn->key);
>>>> + driver_name = db_get_default_driver_name();
>>>> + if (strcmp(driver_name, "pg") == 0)
>>>> + datetime_type = G_store("timestamp with time zone");
>>>> + else if (strcmp(driver_name, "dbf") == 0)
>>>> + datetime_type = G_store("varchar(22)");
>>>> + else
>>>> + datetime_type = G_store("datetime");
>>>> /* dsn is 'PG:', check default connection settings */
>>>> dsn = NULL;
>>>> - if (strcmp(db_get_default_driver_name(), "pg") == 0 &&
>>>> + if (strcmp(driver_name, "pg") == 0 &&
>>>> G_strcasecmp(param.dsn->answer, "PG:") == 0) {
>>>> const char *dbname;
>>>> dbConnection conn;
>>>> @@ -1010,7 +1021,7 @@
>>>> sprintf(buf, ", %s time", Ogr_fieldname);
>>>> else if (Ogr_ftype == OFTDateTime) {
>>>> - sprintf(buf, ", %s datetime", Ogr_fieldname);
>>>> + sprintf(buf, ", %s %s", Ogr_fieldname,
>>>> datetime_type);
>>>> #endif
>>>> else if (Ogr_ftype == OFTString) {
>>>> _______________________________________________
>>>> grass-commit mailing list
>>>> grass-commit at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/grass-commit
>>> Hi,
>>> this revision broke running v.in.ogr during creating a new location with
>>> Location Wizard based on georeferenced file (e.g. shapefile). User is asked
>>> if he wants to also import the data into that location and then it fails
>>> because v.in.ogr crashes. The problem is on line
>>> driver_name seems to be NULL. Running the same v.in.ogr command after
>>> starting normal grass session works. Is there and initialization missing?
>> I added db.connect -c before importing the vector in gis_set.py. That
>> seems to solve it (r61815, and backported in r61816).
>>> Thanks,
>>> Anna
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140906/1b5e8dbb/attachment-0001.html>
