[GRASS-dev] [GRASS GIS] #2349: CELL raster format: make ZLIB level 3 standard compression instead of RLE
trac at osgeo.org
Sat Sep 6 17:45:31 PDT 2014
Reporter: neteler | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: blocker | Milestone: 7.0.0
Component: Raster | Version: svn-releasebranch70
Keywords: compression, r.compress | Platform: All
Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:12 neteler]:
> It seems that the NULL file is not compressed (file "cell_misc/null").
According to
> http://lists.osgeo.org/pipermail/grass-user/2010-January/054216.html
> it is one bit (null/non-null) for each cell.
> Question: Would it be possible to compress also the null files, even
with just a
> weak compression?
Being uncompressed, the null files don't contain an index. The offset to
the beginning of a given row is obtained by multiplying the row number by
the number of bytes per row (which is just the number of columns divided
by 8, rounded upwards).
The main issue is likely to be the need to support both formats. We need
to
* Be able to read and write the uncompressed format, for compatibility
with existing versions of GRASS.
* Be able to distinguish between compressed and uncompressed formats on
read.
* Provide some mechanism (i.e. yet another environment variable) to
indicate which format to use on write.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2349#comment:13>
