[GRASS-dev] [GRASS GIS] #2409: last call for options keys consolidation
trac at osgeo.org
Sun Sep 7 20:03:46 PDT 2014
Reporter: martinl | Owner: grass-dev@…
Type: task | Status: new
Priority: blocker | Milestone: 7.0.0
Component: Default | Version: unspecified
Keywords: standardized options | Platform: Unspecified
Cpu: Unspecified |
Comment(by neteler):
Excluded yes, but then it breaks:
(note: I use the Euro sign as field separator for the CSV file since most
of the chars are taken)
GRASS 7.1.svn (nc_spm_08_grass7):~/software/grass-sandbox/martinl > python
print_module_parameters_csv.py
g.mremove€f€Force removal (required for actual deletion of files)
g.mremove€b€Remove base raster maps
g.mremove€type€Data type(s)
g.mremove€pattern€Map name search pattern
g.mremove€exclude€Map name exclusion pattern (default: none)
File "print_module_parameters_csv.py", line 23, in <module>
main()
File "print_module_parameters_csv.py", line 12, in main
task = gtask.grassTask(cmd)
File "/home/neteler/software/grass71/dist.x86_64-unknown-linux-
gnu/etc/python/grass/script/task.py", line 70, in __init__
self.errorMsg = e.value
AttributeError: 'ScriptError' object has no attribute 'value'
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:4>
