[GRASS-dev] [GRASS GIS] #2410: Python ScriptError
GRASS GIS trac at osgeo.org
Mon Sep 8 02:24:04 PDT 2014
 Reporter:  martinl      |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  7.1.0
Component:  Python       |     Version:  svn-trunk
 Keywords:  ScriptError  |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by zarch):
 Replying to [ticket:2410 martinl]:
 > In trunk Python Scripting Library is used !ScriptError from PyGRASS
 source:grass/trunk/lib/python/script/core.py#L36. It was introduced in
 r61187 by zarch. In relbr70 is still used it's own implementation of
 `ScriptError`
 source:grass/branches/releasebranch_7_0/lib/python/script/core.py#L70
 which defines attribute `value`. This attribute is accessed on many places
 of Python Scripting Library or wxGUI, eg.
 >             except ScriptError as e:
 >                 self.errorMsg = e.value
 > Since `ScriptError` from PyGRASS doesn't have this attribute, it fails
 with
 >   File "/opt/src/grass_trunk/dist.x86_64-unknown-linux-
 gnu/etc/python/grass/script/task.py", line 70, in __init__
 > AttributeError: 'ScriptError' object has no attribute 'value'
 Right I did this change, we can modify ScriptError back to:
 class ScriptError(Exception):
     def __init__(self, msg):
         self.value = msg
     def __str__(self):
         return self.value
 # --- or alternatively
     @property
     def value(self):
         return self.args[0]
 or change the e.value to e.args[0]
 The value property seems to be used in:
 $ grep --color=auto --exclude-dir={.svn,.git,.OBJ,locale,dist.x86_64
 -unknown-linux-gnu} -IrnE "\se\.value"
 lib/python/script/task.py:70:                self.errorMsg = e.value
 gui/wxpython/vnet/vnet_utils.py:80:        e = e.value
 gui/wxpython/vnet/vnet_utils.py:119:        e = e.value
 gui/wxpython/psmap/instructions.py:1546:            GError(message =
 e.value)
 gui/wxpython/psmap/instructions.py:1584:                    GError(message
 = e.value)
 gui/wxpython/psmap/instructions.py:1717:            GError(message =
 e.value)
 gui/wxpython/mapwin/buffered.py:821:            GError(message = e.value)
 gui/wxpython/location_wizard/wizard.py:2140:            return e.value
 gui/wxpython/core/settings.py:48:            print >> sys.stderr, e.value
 gui/wxpython/nviz/mapwindow.py:1355:                       message =
 e.value)
 gui/wxpython/nviz/mapwindow.py:1397:                       message =
 e.value)
 gui/wxpython/dbmgr/base.py:93:                   message = e.value)
 gui/wxpython/dbmgr/base.py:1814:                       message =
 _("Loading attribute data failed.\n\n%s") % e.value)
 gui/wxpython/dbmgr/base.py:1839:                           message =
 gui/wxpython/wxplot/histogram.py:189:                   message = e.value)
 gui/wxpython/wxplot/scatter.py:195:                   message = e.value)
 Personally I think that we should change the ScriptError class definition.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2410#comment:1>
