[GRASS-dev] [GRASS GIS] #2412: Separate parameters to set the colour of the polygon fill and boundary/lines using a colour definition column
trac at osgeo.org
Tue Sep 9 04:28:52 PDT 2014
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.1.0
Component: Default | Version: svn-trunk
Keywords: vector,colour | Platform: Unspecified
Cpu: Unspecified |
For polygons it would be a nice addition if the colour of the fill and
boundary could be defined separately based on colour definition columns
(rgb_fill_column and rgb_line_column instead of rgb_column).
Together with the width_column parameter these would allow for an easier
definition of the looks of a (polygon) map.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2412>
