[GRASS-dev] [GRASS GIS] #2136: Create standard options for map or file base name (prefix)
trac at osgeo.org
Tue Sep 9 09:36:12 PDT 2014
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.0
Component: Parser | Version: svn-releasebranch64
Keywords: base name, prefix, basename | Platform: All
Cpu: All |
Comment(by martinl):
Replying to [comment:28 wenzeslaus]:
> I think that's OK. I think that basename as input will be a rare case.
For `t.*` you use dataset name (and basename as optional for output maps),
generally you use list of maps (no basenames usually involved), and
finally, most of the examples we have now has only the output basename
(e.g., `r.texture`). The rare cases can always change it. But if you
insist on `basename_output`, I can see why, it would be more explicit and
also consistent with `output`.
anyone else with opinion?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2136#comment:29>
