[GRASS-dev] Error reading null row 2725 for <MASK>
Paulo van Breugel
p.vanbreugel at gmail.com
Tue Sep 9 23:35:10 PDT 2014
I did. I recompile and see if that takes care of the problem.
On Wed, Sep 10, 2014 at 1:10 AM, Markus Neteler <neteler at osgeo.org> wrote:
> On Thu, Aug 28, 2014 at 7:34 AM, Paulo van Breugel
> <p.vanbreugel at gmail.com> wrote:
> > On Wed, Aug 27, 2014 at 8:20 PM, Markus Neteler <neteler at osgeo.org>
> wrote:
> >> On Wed, Aug 27, 2014 at 3:25 PM, Paulo van Breugel
> >> > I forgot to mention that I am using GRASS 7.1 (rev 61757, had it
> before
> >> > with rev 61413, but I think I had a similar problem about a year ago).
> >> > On Wed, Aug 27, 2014 at 10:13 AM, Paulo van Breugel
> >> >> When running several r.mapcalc in a loop (via R) the function stops
> >> >> with an error:
> >> >> ERROR: Error reading null row 2725 for <MASK>
> >> The error comes from read_null_bits() in
> >> lib/raster/get_row.c
> >> around
> http://trac.osgeo.org/grass/browser/grass/trunk/lib/raster/get_row.c#L827
> >> Maybe some off_t definition is missing?
> > I don't know what that means; indication of something being wrong with
> the
> > data, or in the code?
> Question: did you compile with --with-pthread?
> AFAIK it causes troubles.
> Markus
> >> >> The row number varies. This seems to happen at random, and when I
> >> >> repeat
> >> >> the same r.mapcalc calculation that stopped with the error before,
> >> >> things run without problem.
> >> Please tell us also
> >> - how many raster cells are involved
> >> - how many files are opened in the loop?
> > Last time the error occured in the r.mapcalc below:
> > The command:
> > r.mapcalc --overwrite expression="OUTPUT = if(MESSC==0, 100000* 100.0 *
> > (MESSB-12300000)/(382900000-12300000), if(MESSC<=5000000, 2*MESSC,
> > if(MESSC<=10000000, 2*(10000000-MESSC),100000 * 100.0 * (382900000-
> > MESSB)/(382900000-12300000))))"
> > produced an error (1) during execution:
> > These layers have 6515140 raster cells, with 3366825 total null cells.
> The
> > command is part of a sequence of commands that is run in a loop, but
> these
> > are run in sequence so at the time of the error I guess two layers were
> > open. As I mentioned, running the command again and it will normally run
> > without problems with the given input layers, and it may go wrong with
> other
> > input layers again, without any discernible logic to me.
> >> >> I tried after removing the mask, and this time no problem so it may
> >> >> have
> >> >> to do something with the MASK? (as these error messages only occur
> once
> >> >> in a
> >> >> while, I can't be completely sure it only happens when a MASK is
> >> >> defined).
> >> >> I ran it through R, using the execGRASS() function of the spgrass6
> >> >> package. I ran the same, but using the system call instead of
> >> >> execGRASS.
> >> >> Still got the same error messages. I therefore guess this has nothing
> >> >> to do
> >> >> with R?
> >> Could you "simulate" the loops in a GRASS script outside of R to see
> >> if it the same?
> > I'll have to figure out how to do that. Perhaps running the r.mapcalc
> above
> > several times will do the trick.
> >> Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140910/54382936/attachment-0001.html>
