[GRASS-dev] [GRASS-SVN] r60703 - in grass/trunk: display/d.vect general/g.gisenv gui/wxpython/animation lib/python/temporal raster/r.colors raster/r.external raster/r.in.bin raster/r.mapcalc raster/r.neighbors raster/r.out.bin raster/r.quant raster/r.resamp.filter raster/r.series raster/r.series.accumulate raster/r.series.interp raster/r.stats.quantile vector/v.colors vector/v.external.out
Anna Petrášová
kratochanna at gmail.com
Sat Sep 13 17:14:29 PDT 2014
On Tue, Jul 22, 2014 at 2:58 PM, Huidae Cho <grass4u at gmail.com> wrote:
> Hi,
> Well, there are no equivalent functions in python yet. Other than that, I
> think this new API is functionally satisfying and r.clump is using it. The
> patch looks good to me. BTW, I prefer option= and -f.
could you or Glynn backport this new API?
Thanks,
Anna
> Regards,
> Huidae
> On Tue, Jul 22, 2014 at 1:53 PM, Anna Petrášová <kratochanna at gmail.com>
> wrote:
>> On Wed, Jun 25, 2014 at 2:09 AM, Huidae Cho <grass4u at gmail.com> wrote:
>>> We also need to add option_rules or something to g.parser so that python
>>> scripts can have access to these functions. Something like:
>>> #%option_rules
>>> #% exclusive: -a, -b
>>> #% requires_all: opt1, opt2, -a
>>> #%end
>>> On Fri, Jun 20, 2014 at 9:59 PM, Huidae Cho <grass4u at gmail.com> wrote:
>>>> G_option_excludes() works for me.
>>>> On Fri, Jun 20, 2014 at 7:58 PM, Glynn Clements <
>>>> glynn at gclements.plus.com> wrote:
>>>>> Huidae Cho wrote:
>>>>> > I assume G__check_option_rules() is supposed to be called by
>>>>> G_parser().
>>>>> > Then, instead of calling G_fatal_error, it should append errors to
>>>>> > st->errors.
>>>>> Okay; I presume that the intent is so that it will report all errors,
>>>>> not just the first.
>>>>> > If so... for g.mlist we can define two different versions of
>>>>> > rules:
>>>>> > This version prints more correct errors because only present
>>>>> options/flags
>>>>> > will be displayed in errors, but too much typing.
>>>>> > G_option_exclusive(flag.regex, flag.extended, NULL);
>>>>> > G_option_exclusive(flag.pretty, flag.full, NULL);
>>>>> > G_option_exclusive(flag.pretty, opt.output, NULL);
>>>>> > G_option_exclusive(flag.pretty, flag.mapset, NULL);
>>>>> > G_option_exclusive(flag.pretty, flag.type, NULL);
>>>>> > G_option_exclusive(flag.full, opt.output, NULL);
>>>>> > G_option_exclusive(flag.full, flag.mapset, NULL);
>>>>> > G_option_exclusive(flag.full, flag.type, NULL);
>>>>> > This version is shorter, but -p -f will print three errors including
>>>>> > options/flags not present.
>>>>> > G_option_exclusive(flag.pretty, flag.full, opt.output, NULL);
>>>>> > G_option_exclusive(flag.pretty, flag.full, flag.mapset, NULL);
>>>>> > G_option_exclusive(flag.pretty, flag.full, flag.type, NULL);
>>>>> > Can we implement something like
>>>>> > G_option_exclusive(pretty, full, G_option_or(output, mapset, type))
>>>>> I'd rather stick to "flat" rules rather than heading in the direction
>>>>> of generalised boolean expressions.
>>>>> Not because it's hard to implement, but because it makes it harder to
>>>>> utilise the information.
>>>>> The next logical step is to include the rules in the
>>>>> --interface-description output so that the GUI can convey the
>>>>> relationships to the user. E.g. mutually-exclusive options might use
>>>>> radio buttons, or greying-out excluded options. Options which are
>>>>> required by another option could be marked as "required" when a value
>>>>> is given for the first option. And so on.
>>>>> Realistically, that requires that the rules belong to a finite set of
>>>>> patterns.
>>>>> > pretty, full, and any of output, mapset, and type are mutually
>>>>> exclusive,
>>>>> > but output, mapset, and type are not exclusive.
>>>>> How about another rule type:
>>>>> > G_option_excludes(flag.pretty, opt.output, flag.mapset,
>>>>> flag.type, NULL);
>>>>> > G_option_excludes(flag.full, opt.output, flag.mapset,
>>>>> flag.type, NULL);
>>>>> where the first option excludes all remaining options.
>>>>> This is essentially the negation of G_option_requires().
>>>>> Glynn Clements <glynn at gclements.plus.com>
>>> grass-dev mailing list
>>> grass-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
>> Hi,
>> is this new API now stable enough to be actually used in C modules?
>> Should we start to replace the manual checks in modules with these
>> functions? BTW, documentation is still missing.
>> I attached a patch which should fix this ticket [1]: when user doesn't
>> type any command arguments and the module has no explicitly required
>> options (like g.region), it checks if there is any RULE_REQUIRED and if
>> yes, it opens GUI dialog.
>> Also I would consider a little bit better error message, the name of the
>> option is not very visible in the sentence. Perhaps using quotes or <>
>> around the option would help. Also, "Option myoption1 requires at least one
>> of myoption2" sounds weird, perhaps there should be special handling of
>> cases when there is just one option required. These are just details.
>> Thanks,
>> Anna
>> [1]http://trac.osgeo.org/grass/ticket/1778
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140913/4ad7451c/attachment.html>
