[GRASS-dev] [GRASS GIS] #2258: t.create creates DB always in the PERMANENT
trac at osgeo.org
Sun Sep 14 07:44:55 PDT 2014
Reporter: martinl | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.0
Component: Temporal | Version: svn-releasebranch70
Keywords: t.register | Platform: Unspecified
Cpu: Unspecified |
Comment(by martinl):
Replying to [comment:12 glynn]:
> Replying to [comment:11 huhabla]:
> > So, what would be the best solution?
> Place the SQLite database file in the mapset directory by default. Any
other location should only be used if specifically requested by the user.
> Assuming that the current user can write to locations other than the
current mapset directory, their home directory, or the temporary directory
(/tmp or $TMPDIR), is a bug.
Is it planned any progress in this issue? Would be nice to reduce number
of blockers slowly to zero...
Ticket URL: <http://trac.osgeo.org/grass/ticket/2258#comment:13>
