[GRASS-dev] [GRASS GIS] #2258: t.create creates DB always in the PERMANENT
GRASS GIS trac at osgeo.org
Sun Sep 14 12:47:38 PDT 2014
 Reporter:  martinl      |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  blocker      |   Milestone:  7.0.0
Component:  Temporal     |     Version:  svn-releasebranch70
 Keywords:  t.register   |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by huhabla):
 Replying to [comment:13 martinl]:
 > Replying to [comment:12 glynn]:
 > > Replying to [comment:11 huhabla]:
 > > > So, what would be the best solution?
 > > Place the SQLite database file in the mapset directory by default. Any
 other location should only be used if specifically requested by the user.
 > > Assuming that the current user can write to locations other than the
 current mapset directory, their home directory, or the temporary directory
 (/tmp or $TMPDIR), is a bug.
 > Is it planned any progress in this issue? Would be nice to reduce number
 of blockers slowly to zero...
 Work in progress. I have applied the patches from #2408 in r61956 and
 r61957. This is the basis for a larger patch, that enables distributed
 temporal datasets (patch is attached, but very experimental). I will
 switch to mapset specific temporal databases in case the new approach
 works stable.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2258#comment:14>
