[GRASS-dev] [GRASS GIS] #2413: pygrass: number_of wrong	function associated
    trac at osgeo.org
    Mon Sep 15 01:03:04 PDT 2014
 Reporter:  artegion        |       Owner:  grass-dev@…
     Type:  defect          |      Status:  new
 Priority:  normal          |   Milestone:  6.4.5
Component:  Python          |     Version:  svn-releasebranch70
 Keywords:  pygrass vector  |    Platform:  All
      Cpu:  Unspecified     |
Comment(by artegion):
 Replying to [comment:4 lucadelu]:
 > Replying to [comment:3 lucadelu]:
 > > It seems better, but it is still strange the result of schools map
 (lines=167,points=5)
 > Reading the documentation it is more clear, the description of function
 ''Vect_get_num_lines'' is:
 > Fetch number of features (points, lines, boundaries, centroids) in
 vector map
 It seems wrong use of '''Vect_get_num_line_points''' function in _NUMOF.
 Vect_get_num_line_points: Get number of line points and takes a pointer to
 line_pnts structure (not a pointer to Map_info struct).[[BR]]
 the correct form of _NUMOF  shoud be
 _NUMOF = {"areas": libvect.Vect_get_num_areas,
           "dblinks": libvect.Vect_get_num_dblinks,
           "faces": libvect.Vect_get_num_faces,
           "holes": libvect.Vect_get_num_holes,
           "islands": libvect.Vect_get_num_islands,
           "kernels": libvect.Vect_get_num_kernels,
           "lines": libvect.Vect_get_num_lines,
           "nodes": libvect.Vect_get_num_nodes,
           "updated_lines": libvect.Vect_get_num_updated_lines,
           "updated_nodes": libvect.Vect_get_num_updated_nodes,
           "volumes": libvect.Vect_get_num_volumes}
Ticket URL: <http://trac.osgeo.org/grass/ticket/2413#comment:5>
