[GRASS-dev] [GRASS GIS] #2402: v.distance in Long/Lat Locations on GRASS 7.0
GRASS GIS trac at osgeo.org
Mon Sep 15 11:41:16 PDT 2014
 Reporter:  micha        |       Owner:  grass-dev@…
     Type:  enhancement  |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  Default      |     Version:  unspecified
 Keywords:               |    Platform:  All
      Cpu:  Unspecified  |
Comment(by mmetz):
 Replying to [comment:7 mlennert]:
 > I just found a difference in distances calculated with grass6 and grass7
 for points to areas (see explanation in #2401). Needs checking.
 G6 and G7 produced nearly identical results after the last change to
 v.distance in trunk, but now (r61978) there is
 Vect_line_geodesic_distance() available in trunk and v.distance makes use
 of it (r61979). The results in latlong are now more similar to the results
 in the original NC projection. In particular, the larger deviations
 present in G6 have now disappeared in trunk.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2402#comment:8>
