[GRASS-dev] [GRASS GIS] #2347: r.ros uses arbitrary direction convention
GRASS GIS trac at osgeo.org
Tue Sep 16 09:30:50 PDT 2014
 Reporter:  madi                     |       Owner:  grass-dev@…
     Type:  defect                   |      Status:  new
 Priority:  normal                   |   Milestone:  7.1.0
Component:  Default                  |     Version:  unspecified
 Keywords:  r.ros, r.spread, angles  |    Platform:  Unspecified
      Cpu:  Unspecified              |
Changes (by wenzeslaus):
  * milestone:  6.4.4 => 7.1.0
Comment:
 If we would like to have this resolved in a way of choosing one direction,
 we would have to mark it as blocker for 7.0.0. However, I think this is
 not feasible and perhaps the better idea actually is to create a new
 option (for `r.ros` and `r.spread`) which will allow to choose between
 different conventions. If the default will be the same as the current it
 will not change the API and everything will be fine. So, increasing the
 milestone.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2347#comment:4>
