[GRASS-dev] [GRASS GIS] #2425: Import translation function instead of using a buildin
trac at osgeo.org
Tue Sep 16 18:35:24 PDT 2014
Reporter: wenzeslaus | Owner: grass-dev@…
Type: task | Status: new
Priority: normal | Milestone: 7.1.0
Component: Translations | Version: svn-releasebranch70
Keywords: python, underscore, _, gettext, doctest | Platform: All
Cpu: Unspecified |
''Here are my notes about this issue since I was forgetting about it.''
On some occasions, some of GRASS functions does not work because of
translation function (`_` - underscore). The problem occurs on some
strange conditions and when you are using Python
[https://docs.python.org/2/library/doctest.html doctest] which we are
using more and more.
There is already several workarounds in wxGUI and also testing framework
as
[wiki:GSoC/2014/TestingFrameworkForGRASS#Findingandrunningthetestmodules
described here]:
> `doctests` currently don't work with grass.script unless you call a
[source:grass/trunk/gui/wxpython/core/toolboxes.py?rev=60218#L630 set of
functions] to deal with function _ (underscore) because of installing
translate function as buildin _ function while _ function is used also in
doctest.
Grep for function `do_doctest_gettext_workaround` to see definition and
how it is used.
I already did this change for wxGUI more then a year ago and it seems to
work. It was necessary because there was some problem with not translated
files and this was only way to fix it besides going against documentation.
For now I don't know how `lib/python`, `scripts`, and `temporal` differs
in translations, so this should be clarified before changing it.
See comment:5:ticket:1739 for deep discussion of the topic.
For wxGUI this was implemented in the r57219 and r57220 as a result of
#1739 and other investigation.
This might be a blocker for some solutions of #2142. The new method should
be flexible allowing to obtain translations from two sources
simultaneously.
Basically, it is necessary to remove all occurrences of:
gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'),
unicode = True)
By one code based on this line in some module:
_ = gettext.translation('grasswxpy', os.path.join(os.getenv("GISBASE"),
'locale')).ugettext
The actual implementation must be more complicated
(changeset:57220#file0).
Then each file, depending on the name and placement of translation
function, must import:
from grass.script.utils import _
from grass.script.translations import _
from grass.*.utils import _
from grass.*.translations import _
from grass.translations import _
Probably `grass.translations` is the best since in GUI a module inside
some other package is creating dependencies (changeset:57219#file10,
changeset:57219#file13).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2425>
