[GRASS-dev] [GRASS GIS] #1739: Language switch on wxGUI doesn't affect all strings
GRASS GIS trac at osgeo.org
Tue Sep 16 18:43:27 PDT 2014
  Reporter:  MilenaN       |       Owner:  grass-dev@…
      Type:  defect        |      Status:  closed
  Priority:  normal        |   Milestone:  7.0.0
 Component:  Translations  |     Version:  unspecified
Resolution:  fixed         |    Keywords:  wxGUI, Python, underscore, _, gettext, doctest
  Platform:  All           |         Cpu:  x86-32
Changes (by wenzeslaus):
  * keywords:  => wxGUI, Python, underscore, _, gettext, doctest
  * resolution:  => fixed
  * status:  new => closed
  * component:  Python => Translations
  * milestone:  6.4.4 => 7.0.0
Comment:
 Replying to [comment:6 marisn]:
 > It should work just fine in GRASS 7 as long as specified language has
 its supporting locale installed. If language lacks matching locale in the
 system, I'm not certain if it can be solved at all. As GRASS 6 and 7
 startup scripts are different, it is not possible to backport changes. I
 would vote for testing in 7 and closing as wontfix for 6.
 No complains since then, so closing as fixed. Feel free open a new ticket
 if you encounter any other problems.
 Related/unresolved:
  * The issue remains for library and modules, follow #2425.
  * Smaller issue related to toolboxes is inside of #2142.
  * r57219 has some code duplication (visible in r57220) which should be
 removed in the future (the solution is probably a separate
 `(wxgui.)translations` package/module).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1739#comment:7>
