[GRASS-dev] v.overlay handles mapname at mapset in a wrong way
Vaclav Petras
wenzeslaus at gmail.com
Wed Sep 17 15:00:15 PDT 2014
On Wed, Sep 17, 2014 at 5:24 PM, Markus Metz <markus.metz.giswork at gmail.com>
wrote:
> On Wed, Sep 17, 2014 at 10:28 PM, Vaclav Petras <wenzeslaus at gmail.com>
> wrote:
> > On Wed, Sep 17, 2014 at 3:50 PM, Markus Metz <
> > wrote:
> >> On Wed, Sep 17, 2014 at 3:33 PM, Vaclav Petras <wenzeslaus at gmail.com>
> >> wrote:
> >> > Hi,
> >> > it seems [1] that v.overlay cannot handle dot in mapset name which
> >> > probably
> >> > points to a wrong handling of mapset in a parameter.
> >> How did you manage to add @<mapset> to the output name? With the GUI
> >> this is not possible. On the command line you should not add @<mapset>
> >> to a vector output (this might apply also to raster output, I did not
> >> check) because output maps are always created in the current mapset.
> > Oh, I didn't realized that.
> GRASS is designed for multi-user environments such as research
> institutions or public administration institutions. A given user has
> write permissions only to its home directory, /tmp or %TMP% and the
> current mapset which the current user owns in terms of permissions
> (dependent on file system and operating system). Any other mapsets are
> assumed to belong to different users. This has been pointed out
> repeatedly before and is a security feature. Even if you are the owner
> of several different mapsets, you are still allowed to create new data
> only in the current mapset. This is a security feature needed e.g. for
> HPC (High Performance Computing).
Considering that you are a GRASS developer you should have realized that.
> Oh, sorry for confusion. I actually know this. I didn't realized that it
is output, not input, and so there shouldn't be any mapset at all.
I was basically just performing the function which the testing framework is
not yet doing: sending emails about what is broken.
Thanks for the explanation anyway, I was recently giving one but next time
I will use yours since it is nicely written. It might and up in the manual
too.
Vaclav
> Markus M
> > The error is caused by t.vect.mapcalc (visible in tests). It seems that
> it
> > is just adding the mapset name there for some reason.
> http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2014-09-17-07-00/report_for_nc_spm_08_grass7_nc/temporal/t.vect.mapcalc/test.t.vect.mapcalc/index.html
> >> The error appears not in the module but in the library, thus affects
> >> all modules who care to check the validity of a vector output name.
> >> IOW, the vector output name must not be a fully qualified name. I have
> >> fixed that in r62023,4 for trunk and relbr_70. The warning is now
> >> WARNING: Illegal vector map name
> >> <tmp_map_name_27967_1 at __temporal_t_vect_mapcalc_test.t.vect.mapcalc>.
> >> Character '@' not allowed.
> >> because '@' occurs before '.' in the fully qualified name.
> > This is much clearer message, thanks.
> > Vaclav
> >> Markus M
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140917/e73187a8/attachment.html>
