[GRASS-dev] [GRASS GIS] #2426: add r.surf.nnbathy to the core code of GRASS 7.1
GRASS GIS trac at osgeo.org
Thu Sep 18 10:03:47 PDT 2014
 Reporter:  bhlevca      |       Owner:  grass-dev@…
     Type:  enhancement  |      Status:  new
 Priority:  major        |   Milestone:  7.1.0
Component:  Addons       |     Version:  unspecified
 Keywords:               |    Platform:  Unspecified
      Cpu:  Unspecified  |
 I find this script much faster and gives better results that
 r.surf.contour.
 I am not sure if there are licensing problems with nnbathy
 (https://code.google.com/p/nn-c/) as it is a MIT license, but my
 understanding is that it should be possible.
 I recently copied manually the script from the Grass6 add on repositories
 into the scripts directory of the Grass7.1 installation directory. I also
 compiled nnbathy from the above sources.
 The Makefile in the grass7 addons did not work although I had the grass6
 addons installed in parallel. Probably that needs fixing as well as a
 temporary measure until nnbathy is properly integrated.
 It worked flawlessly in grass 7.1. The result of a 6000x 10000 nodes was
 given in less than one minute. The r.surf.contour gave me a worse result
 in 192 minutes! That's more than 3 hours and that happened only after I
 lowered the resolution from res=2 to res=6. With res=1 in the g.region the
 r.surf.contour did not advance at all after 2 hours so I had to cancel. In
 addition the quality is not so great from r.surf.contour, especially if
 you have complex shapes.
 I believe many people would benefit from this triangulation (nnbathy)
 method rather than using the linear interpolation method of
 r.surf.contour.
 Please consider of adding r.surf.nnbathy to the main repository.
 Thanks
Ticket URL: <http://trac.osgeo.org/grass/ticket/2426>
