[GRASS-dev] [GRASS GIS] #2429: error message when renaming attribute table column using v.db.renamecol
trac at osgeo.org
Sun Sep 21 10:36:19 PDT 2014
Reporter: jbowers | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.5
Component: Default | Version: unspecified
Keywords: | Platform: Unspecified
Cpu: Unspecified |
When trying to rename a column in a DBF attribute database I get the error
message v.db.addcol cannot be found and the renaming process can't be
completed.
This even occurs when I try to rename columns that have been added to the
database using v.db.addcol
Screenshot attached
Ticket URL: <http://trac.osgeo.org/grass/ticket/2429>
