[GRASS-dev] [GRASS GIS] #2053: r.recode: 0.0 or 1.0 as limits do not seem to be taken into account
GRASS GIS trac at osgeo.org
Sun Sep 21 18:53:37 PDT 2014
 Reporter:  nikosa                                  |       Owner:  grass-dev@…
     Type:  defect                                  |      Status:  new
 Priority:  major                                   |   Milestone:  7.0.0
Component:  Raster                                  |     Version:  unspecified
 Keywords:  r.recode, DCELL, CELL, rules, needinfo  |    Platform:  Unspecified
      Cpu:  Unspecified                             |
Comment(by glynn):
 Replying to [comment:4 annakrat]:
 > Any opinion on the suggested change? This is in my view quite serious
 bug.
 If it's going to deduce the type from the rules, I suggest checking for a
 decimal point prior to parsing rather than checking whether the parsed
 value is exactly representable as an integer. IOW, "0.0:1.0:0:255" will
 perform a float-int recode while "0:1:0:255" will perform a int-int
 conversion.
 I wouldn't suggest using the input map's type for the input type unless
 this will produce identical results.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2053#comment:5>
