[GRASS-dev] v.in.lidar return filter
Anna Petrášová
kratochanna at gmail.com
Mon Sep 22 15:54:27 PDT 2014
I want to import first return points with v.in.lidar, but I get only points
where the pulse had more then one return. So it gives me trees but not
ground or buildings. I looked in the code and there is an 'if' which skips
points with only 1 return:
http://trac.osgeo.org/grass/browser/grass/trunk/vector/v.in.lidar/main.c#L672
So the behavior looks intentional but what's the reason?
Thanks,
Anna
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140922/b9be54ce/attachment.html>
