[GRASS-dev] significant change in g.parser behavior for GRASS 7
Michael Barton
Michael.Barton at asu.edu
Wed Sep 24 16:53:54 PDT 2014
I just learned that using upper case characters for a GRASS 7 module option means that g.parser will not recognize it. That is for module. “r.foo" with options “Abc” and “def”, the command
r.foo Abc=1 def=2
will return an error <Abd=1> is not a valid option.
GRASS 6 does not produce an error in this case. The module will run fine.
This breaks all kinds of existing scripts from GRASS6, as well as scripts that are designed to be chained together. I’ve never seen any discussion of this. Perhaps I missed it because I was in the field or something. Is there a reason for this significant change of g.parser behavior?
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140924/0e3f4f7d/attachment.html>
