[GRASS-dev] Floating and integer numbers in r.mapcalc
Paulo van Breugel
p.vanbreugel at gmail.com
Thu Sep 25 00:02:24 PDT 2014
Hi Glynn
Thanks for the explanation. Good to know that the problem lies with the
exceeding the integer range.. something I have to be careful about in the
future.
On Thu, Sep 25, 2014 at 1:04 AM, Glynn Clements <glynn at gclements.plus.com>
wrote:
> Paulo van Breugel wrote:
> > I have the following function (to calculate cell area)
> > PI=3.1415926536
> > RES=0.0008333
> > R=6371007
> > r.mapcalc "test3 = (sin(y()+$RES/2) - sin(y()-$RES/2)) * ($RES *
> $PI/180) *
> > $R^2"
> > This will give me a wrong results, apparently because R is an integer
> > value. If I adapt the formula:
> $PI/180) *
> > float($R)^2"
> > I get the correct result. From the help file I understand that if any of
> > the arguments is a floating number the result should be a floating
> number.
> > But that does not seem the case above so apparently I am missing
> something
> > here. Can anybody explain the logic behind the above?
> In the first case, 6371007^2 is calculated using integer arithmetic,
> and the result (40589730194049) will exceed the range of an "int"
> (2^31-1 = 2147483647), typically resulting in overflow (R^2 will
> probably equal -2005720447). The value will be converted to "double"
> for the multiplication, but by that point the error has already
> occurred.
> In the second case, R is converted to "float" (single-precision
> floating-point), and the result of squaring it is well within the
> range of a "float", although it will be rounded to 40589731037184.0
> (using double() instead of float() will use double-precision and avoid
> the rounding error).
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140925/121893d6/attachment-0001.html>
