#2428: r.external to accept gdal config options
Reporter: perrygeo | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.1.0
Component: Default | Version: svn-trunk
Keywords: r.external | Platform: Unspecified
Cpu: x86-64 |
Comment(by glynn):
Replying to [comment:1 neteler]:
> The request sounds reasonable but I didn't figure out how to pass
"papszOptions" to GDAL as used in r.external. The magic line in r.out.gdal
is this:
> but in r.external GDALOpen() is used. Perhaps a GDAL expert can tell us
the trick.
Note that r.external is the analogue of r.in.gdal, which doesn't accept
any configuration options.
The analogue of r.out.gdal is r.external.out, which has an options=
option.
If options are needed for reading, a similar option should be added to
both r.in.gdal and r.external, presumably using GDALOpenEx() instead of
GDALOpen(). The latter will require extending the GDAL "link" format
(lib/raster/gdal.c).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2428#comment:2>
