[GRASS-dev] significant change in g.parser behavior for GRASS 7
Michael Barton Michael.Barton at asu.edu
Thu Sep 25 20:56:23 PDT 2014
Thanks for the explanation Glynn. So this is a byproduct of changes for other goals. It is good to learn that a work around can be simply re-odering the options. This makes it easier to maintain chaining between scripts or calling modules from other programs. This behavior is still a potential gotcha for anyone writing scripts, however. Sometimes it will give an ambiguous error and a similar script with a different order of options will not.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Sep 25, 2014, at 4:40 PM, Glynn Clements <glynn at gclements.plus.com> wrote:
> Michael Barton wrote:
>> I just learned that using upper case characters for a GRASS 7 module
>> option means that g.parser will not recognize it.
> Technically, the change is to G_parser(); g.parser simply inherits the
> behaviour.
>> That is for module. �r.foo" with options �Abc� and �def�, the
>> command
>> r.foo Abc=1 def=2
>> will return an error <Abd=1> is not a valid option.
> No it won't.
> However, this will produce that error:
> 	r.foo def=2 Abc=1
> If the first argument doesn't match the required syntax (e.g. because
> of an upper-case character in the option name), it will be treated as
> the value to the default (first) option. IOW, assuming that "Abc" is
> the first option, your example:
> 	r.foo Abc=1 def=2
> will be treated as:
> 	r.foo Abc=Abc=1 def=2
>> GRASS 6 does not produce an error in this case. The module will run fine.
>> This breaks all kinds of existing scripts from GRASS6, as well as
>> scripts that are designed to be chained together. I�ve never seen
>> any discussion of this. Perhaps I missed it because I was in the
>> field or something. Is there a reason for this significant change of
>> g.parser behavior?
> The changes in question are r32259 and r32261, from July 2008, and
> r33576 from September 2008.
> The rationale was related to changing r.mapcalc to use G_parser().
> Following that change, if r.mapcalc is run as e.g.
> 	r.mapcalc "map=expression"
> G_parser() will complain that there is no option named "map".
> The preferred way of avoiding this issue is to place spaces around the
> "=" sign; a space before the "=" guarantees that the argument will not
> be treated as having the option=value form, and will instead be
> treated as the value to the default option (expression=).
> In order to maximise compatibility with the previous version, the test
> for whether an argument has the option=value form was restricted. Any
> argument not conforming to the (newly-restricted) syntax will be
> treated as the value of the expression= option. The more restrictive
> the syntax, the fewer expressions will be mistaken for option=value.
> Originally, any argument containing an "=" was considered as having
> the option=value form.
> r32259 changed this to require that the character immediately before
> the first "=" was not a space or tab. r32261 refined it to require the
> character to be a lower-case letter or a digit. r33576 further refined
> this so that the entire portion before the first "=" must consist
> solely of lower-case letters, digits and underscores, and the
> character immediately before the "=" must not be an underscore.
> With one exception; all option names used in GRASS' own modules and
> scripts already satisfied the new restrictions. The sole exception was
> r.terraflow, which had the STREAM_DIR= option renamed to stream_dir=
> in r32260.
