[GRASS-dev] What is the status of g.list, g.remove, g.mlist and g.mremove?
Markus Neteler
neteler at osgeo.org
Fri Sep 26 02:48:21 PDT 2014
Hi Huidae,
On Thu, Sep 25, 2014 at 6:20 PM, Huidae Cho <grass4u at gmail.com> wrote:
> Markus,
> Currently, g.remove supports "g.remove vect pattern=map1,map2". Pattern can
> take multiple map names separated by a comma.
ok, good. Perhaps I got just confused because the help text does not
show this yet:
current:
g.remove [-refb] type=datatype[,datatype,...] pattern=string
expected:
g.remove [-refb] type=datatype[,datatype,...] pattern=string[,string,...]
It would be multiple = YES for pattern to have that but I don't know
if any other changes might be required then.
Best
Markus
