[GRASS-dev] [GRASS GIS] #2436: v.out.postgis: Unsupported geometry type / Unable to write feature in vector map
GRASS GIS trac at osgeo.org
Sun Sep 28 14:34:20 PDT 2014
vector map
 Reporter:  martin         |       Owner:  grass-dev@…
     Type:  defect         |      Status:  new
 Priority:  normal         |   Milestone:
Component:  Vector         |     Version:  svn-trunk
 Keywords:  v.out.postgis  |    Platform:  Linux
      Cpu:  x86-64         |
 This package:
   http://foxtrot.mgras.net/static/newcs_correct_collect.tbz
 contains a packed vector map plus a little text file.
 The top of the text file shows two commands to export the vector map into
 PostGIS (PostGIS geometry, no topology). The "v.out.ogr" works as
 promised but the "v.out.postgis" doesn't ....  and the bottom part of the
 text file contains the corresponding debug output.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2436>
