[GRASS-dev] [GRASS GIS] #2423: r.series.interp missing in wxGUI menu
trac at osgeo.org
Mon Sep 29 08:40:44 PDT 2014
Reporter: jbrauner | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.1.0
Component: wxGUI | Version: svn-trunk
Keywords: r.series.interp, wxGUI, menu | Platform: All
Cpu: All |
Comment(by wenzeslaus):
Replying to [comment:2 jbrauner]:
> I ''try'' to deduct my thinking process here ... which lead to the patch
> Replying to [comment:1 neteler]:
> > I would be happy to intergrate tge missing item but it is not clear to
me which files to edit:
> > ls gui/wxpython/xml/*.xml
> > main_menu.xml menudata_psmap.xml module_tree_menudata.xml
toolboxes.xml
> > menudata_modeler.xml menudata.xml module_tree.xml
wxgui_items.xml
> I somehow figured out (after checking the wxGUI developer documentation
and the source code), that it has to be {{{toolboxes.xml}}}, because
There was [source:grass/trunk/gui/wxpython/wxguitoolboxes.dox?rev=57001 a
documentation for this] in programming manual but it was deleted few days
ago in r62097. However, there is still a user-oriented documentation which
applies almost completely:
* http://grass.osgeo.org/grass71/manuals/wxGUI.toolboxes.html
(except for location of the files)
> > What is the role of
> > gui/wxpython/tools/update_menudata.py
> this script delivers a list of all possible menuentries and
{{{toolboxes.xml}}} based on {{{menudata.xml}}} provides the structure,
place and the labels used in the menu.
See, (removed) documentation
(source:grass/trunk/gui/wxpython/wxguitoolboxes.dox?rev=57001#L224).
Perhaps we could remove the script now. I would have to double check.
Anyway, use `make` and see what happens, if nothing do `make clean`, maybe
`rm ...dist.../etc/gui` and `make` (or simple or time consuming `make
distclean && make`).
> Again, that was somehow a noobish deduction - but that's the best I can
deliver right now. :)
If you want some example of a change, see the changes in r60768
(backported r60771).
I'm not doing the change because I don't know if "Overlay rasters" is the
right toolbox/group/submenu for `r.series.interp`, interpolation is not
really an overlay operation. Perhaps `r.series.accumulate` should go there
(which is also not in the menu).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2423#comment:3>
