[GRASS-dev] [GRASS GIS] #2437: order parameters in g.remove window
trac at osgeo.org
Mon Sep 29 12:34:11 PDT 2014
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.1.0
Component: Default | Version: unspecified
Keywords: g.remove | Platform: All
Cpu: Unspecified |
On the 'required' tab of the g.remove function you first need to select
the data type from a list. Below one need to type the map name search
pattern.
I have no clue if that is specific for my computer, but for the latter
(the map name search pattern) I have to scroll down as the list of data
types is longer then the height of the g.remove screen.
I only ever need to select raster or vector (and I guess those are amongst
the most used by the majority of users), so the scrolling to get to the
bottom could be avoided by first being presented by the map name search
pattern box and than the data type. For me that order makes more sense
anyway, but that is just a personal preference.But having rsi problems,
anything that could reduce the use of the mouse, however little, would be
welcome (I know, I can use the command line more, and I try as much as
possible).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2437>
