[GRASS-dev] SVN trunk issue with g.list and g.remove (and solution)
Huidae Cho
grass4u at gmail.com
Tue Sep 30 11:16:39 PDT 2014
Hmm... I "remove"d g.list/g.remove and "rename"d g.mlist/g.mremove. Maybe,
there is a better way?
On Tue, Sep 30, 2014 at 1:19 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Tue, Sep 30, 2014 at 12:02 PM, Markus Neteler <neteler at osgeo.org>
> wrote:
>> On Tue, Sep 30, 2014 at 5:25 PM, Vaclav Petras <wenzeslaus at gmail.com>
>> wrote:
>> > Confirmed, I had to do the same in all copies too some time ago. SVN is
>> not
>> > really good at renaming and deleting things, it is always confused and I
>> > really don't understand why I need to do revert.
>> As this almost never happened, it may have been this specific commit
>> being different from others.
>> Whatever, the solution we have.
>> Oh, now I hope it was not because I recommended some Git-like procedure
> to Huidae which is not really what SVN wanted. Anyway, it was easy to solve
> although it required manual intervention to automatic builds (at least the
> one for tests).
>> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140930/be9f655f/attachment-0001.html>
