[GRASS-dev] [GRASS GIS] #2606: Bugs in r.sun
GRASS GIS trac at osgeo.org
Mon Apr 6 21:30:37 PDT 2015
 Reporter:  ojni0001  |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  normal    |   Milestone:  7.0.1
Component:  Raster    |     Version:  unspecified
 Keywords:  r.sun     |    Platform:  MSWindows 7
      Cpu:  x86-64    |
Comment(by ojni0001):
 Creating Python script is not possible for me at the moment. I have
 created a shell script running in Windows7 OS. So, I guess it also runs on
 Linux machine.
 The script does not assume that data is present. It will create a raster
 data with 1 cell and runs the test.
 I cannot find a way to attach the code. Please see the script below:
 #!sh
 function fcomp() {
     awk -v n1=$1 -v n2=$2 'BEGIN{ if (n1<n2) exit 0; exit 1}'
 echo "running test for ticket no. 2606" > test_2606.txt
 g.mapset PERMANENT
 g.proj -c epsg=2449
 g.region s=-83700 n=-83600 w=-23200 e=-23100 res=100
 r.mapcalc --overwrite "const_elev = 15.0"
 days=( 17 47 75 105 135 162 198 228 258 288 318 344)
 month=( jan feb mar apr may jun jul aug sep oct nov dec)
 aspect=( 0.0 15.0 30.0 45.0 60.0 75.0 90.0 105.0 120.0 135.0 150.0 165.0
 180.0 195.0 210.0 225.0 240.0 255.0 270.0 285.0 300.0 315.0 330.0 345.0
 360.0)
 slope=( 0.0 10.0 20.0 30.0 40.0 50.0 60.0 70.0 80.0 90.0)
 for k in {0..11}
 do
         for i in {0..24}
         do
                 for j in {0..9}
                 do
                         CMD="r.sun --overwrite --quiet
 elevation=const_elev aspect_value=${aspect[$i]} slope_value=${slope[$j]}
 linke_value=1.0 glob_rad=at1-g_${month[$k]}_${slope[$j]}_${aspect[$i]}
 day=${days[$k]} step=0.5"
                         $CMD
                 done
         done
 done
 fail1=0
 fail2=0
 fail3=0
 fail4=0
 count1=0
 count2=0
 count3=0
 for k in {0..11}
 do
         #for i in {0..24}
         #lets check at aspect 0 and 180 degrees, the radiation value
 should be equal if 270 is south
         for i in 0 12
         do
                 ((i2=i+12))
                 for j in {0..9}
                 do
                         x1=`r.info -r
 at1-g_${month[$k]}_${slope[$j]}_${aspect[$i]} | grep "max" | cut -d =  -f
 2 `
                         x2=`r.info -r
 at1-g_${month[$k]}_${slope[$j]}_${aspect[$i2]} | grep "max" | cut -d =  -f
 2 `
                         diff_val=`awk "BEGIN {print $x1-$x2; exit}"`
                         echo "  month: ${month[$k]}     aspect:
 ${aspect[$i]}; ${aspect[$i2]}   slope=${slope[$j]}" >> test_2606.txt
                         echo "          x1=$x1  x2=$x2  difference:
 $diff_val" >> test_2606.txt
                         ((count1=count1+1))
                         if [ $diff_val = 0 ];then
                                 echo "          test passed" >>
 test_2606.txt
                         else
                                 echo "          test failed; bug
 remaining, east/west is not 0/180, south is not 270 degrees" >>
 test_2606.txt
                                 ((fail1=fail1+1))
                         fi
                 done
         done
         wait
 done
 wait
 for k in {0..11}
 do
         #for i in {0..24}
         #lets check at aspect 90 and 270 degrees to check whether 90/270
 is east/west or west/east
         for i in 6
         do
                 ((i2=i+12))
                 for j in {0..9}
                 do
                         x1=`r.info -r
 2 `
                         x2=`r.info -r
 2 `
                         ((count2=count2+1))
                                 echo "          values are equal at 90/270
 bug remaining, east/west is 90/270 degrees" >> test_2606.txt
                                 ((fail2=fail2+1))
                         fi
                 done
         done
         wait
 done
 wait
 for k in {0..11}
 do
         for i in {0..24}
         #for i in 6
         do
                 #for j in {0..9}
                 for j in 7
                 do
                         ((j2=j+1))
                         ((j3=j+2))
                         x1=`r.info -r
 2 `
                         x2=`r.info -r
 at1-g_${month[$k]}_${slope[$j2]}_${aspect[$i]} | grep "max" | cut -d =  -f
 2 `
                         x3=`r.info -r
 at1-g_${month[$k]}_${slope[$j3]}_${aspect[$i]} | grep "max" | cut -d =  -f
 2 `
                         diff_val1=`awk "BEGIN {print $x1-$x2; exit}"`
                         diff_val2=`awk "BEGIN {print $x2-$x3; exit}"`
                         ((count3=count3+1))
 ${aspect[$i]}   slope=${slope[$j]}      ${slope[$j2]}   ${slope[$j3]}" >>
 test_2606.txt
                         echo "          x1=$x1  x2=$x2  x3=$x3
 differences: $diff_val1 $diff_val2" >> test_2606.txt
                         #if [ $diff_val1 > 0 ];then
                         if fcomp 0 $diff_val1; then
                                 echo "          $diff_val1 > 0; OK" >>
 test_2606.txt
                         else
                                 echo "          $diff_val1 < 0;bug
 remaining, ${slope[$j]} has less radiance than ${slope[$j2]}" >>
 test_2606.txt
                                 ((fail3=fail3+1))
                         fi
                         #if [ $diff_val2 > 0 ];then
                         if fcomp 0 $diff_val2; then
                                 echo "          $diff_val2 > 0; OK" >>
 test_2606.txt
                         else
                                 echo "          $diff_val2 < 0;bug
 remaining, ${slope[$j2]} has less radiance than ${slope[$j3]}" >>
 test_2606.txt
                                 ((fail4=fail4+1))
                         fi
                 done
         done
         wait
 done
 wait
 echo "e-w test fail:$fail1 of $count1;  south test fail:$fail2 of $count2"
 >> test_2606.txt
 echo "values for slope 70 and 80 fail:$fail3 of $count3;        values for
 slope 80 and 90 fail:$fail4 of $count3" >> test_2606.txt
Ticket URL: <https://trac.osgeo.org/grass/ticket/2606#comment:4>
