[GRASS-dev] [GRASS GIS] #2648: v.concave.hull fails with small number of points
trac at osgeo.org
Tue Apr 7 11:44:06 PDT 2015
Reporter: annakrat | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.1
Component: Addons | Version: unspecified
Keywords: concave hull | Platform: All
Cpu: Unspecified |
Tested with 3, 4, 5 points, v.concave.hull fails. Depends on threshold and
point configuration, too.
ERROR: Input vector map contains no boundaries.
['v.centroids', '--q',
'input=concave_hull_tmp_31390_delaunay_borders_select',
'output=concave_hull_tmp_31390_delaunay_areas_select'] ended with error
Ticket URL: <http://trac.osgeo.org/grass/ticket/2648>
