[GRASS-dev] [GRASS GIS] #2651: Increase maximum number of vector points available
GRASS GIS trac at osgeo.org
Wed Apr 8 11:25:47 PDT 2015
 Reporter:  dnewcomb                  |       Owner:  grass-dev@…
     Type:  enhancement               |      Status:  new
 Priority:  normal                    |   Milestone:  7.1.0
Component:  Vector                    |     Version:  svn-trunk
 Keywords:  lidar, vector point data  |    Platform:  Unspecified
      Cpu:  Unspecified               |
Changes (by neteler):
  * keywords:  vector point data => lidar, vector point data
  * version:  unspecified => svn-trunk
Comment:
 Replying to [ticket:2651 dnewcomb]:
 > The current number of points in a imported into a vector data layer
 appears to be limited to a 32 bit integer ( 2 billion).
 Isn't this the limit in case of topology being enabled? Did you try to
 disable topology during import?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2651#comment:1>
