[GRASS-dev] [GRASS-user] v.isochrones : error message
Moritz Lennert mlennert at club.worldonline.be
Tue Apr 14 01:05:36 PDT 2015
On 13/04/15 21:25, image93 wrote:
> Hello,
> I removed the current extension and then reinstall it
> g.extension v.isochrones op=remove -f
> g.extension v.isochrones op=add
> i'am working with windows 7 32 bit OS.
> I found the path pointing to the v.isochrones.bat :
> C:\Users\laurent\AppData\Roaming\GRASS7\addons\bin
> Moreover, when i launch the v.isochrones GUI , METHOD and COST_COLUMN
> parameters are still  not available. The installation of the new extension
> does not work on my side. g.extension is still reinstalled the old version.
> Is this a problem of repostory? There are several the repositories for Grass
> extensions? i don't know.
I found it: for grass70, the repository is
http://wingrass.fsv.cvut.cz/grass70/addons/grass-7.0.0/ and the
v.isochrones there is still the old version.
Martin, shouldn't updates to addons in addons/grass7 automatically be
updated for this repository as well ? Or do we have a special grass70
addons repository ?
Laurent, what you can do while this is sorted out is to download
v.isochrones.py from
https://trac.osgeo.org/grass/browser/grass-addons/grass7/vector/v.isochrones/v.isochrones.py
Click on 'Original Format' at the bottom of the page and overwrite the
existing v.isochrones.py on your machine with this. Attention: this is
v.isochrones.py, not v.isochrones.bat. You can open the latter in a text
editor to check where the former is located.
Moritz
