[GRASS-dev] [GRASS GIS] #2621: r.random.cells should use NULL instead of 0
trac at osgeo.org
Wed Apr 15 02:22:46 PDT 2015
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.1
Component: Raster | Version: svn-releasebranch70
Keywords: r.random.cells | Platform: Unspecified
Cpu: Unspecified |
Comment(by marisn):
Replying to [comment:4 neteler]:
> Maybe. However, the 7.0 manual states "The cells are numbered from 1 to
the
> numbers of cells generated." which is not true.
Then the manual needs to be fixed. (It also doesn't state that empty cells
have NULLs thus manual is not contradicting current behaviour.)
How about adding a simple sentence "Empty cells are marked with 0 (will be
changed to NULL in GRASS GIS 7.1.0 release)."?
I would say - fix documentation, add to GRASS 7.1 changes and close this
issue.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2621#comment:5>
