[GRASS-dev] Rare t.rast.to.vect and t.rast.contour failures
Vaclav Petras
wenzeslaus at gmail.com
Wed Apr 15 11:50:38 PDT 2015
apparently t.rast.to.vect and t.rast.contour tests fail time to time.
t.rast.to.vect failed on March 26 (r64922):
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-03-26-07-00/report_for_nc_spm_08_grass7_nc/temporal/t.rast.to.vect/test_to_vect/index.html
and test's stdout looked also quite unsettled:
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-03-26-07-00/report_for_nc_spm_08_grass7_nc/temporal/t.rast.to.vect/test_to_vect/stdout.html
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-04-15-07-00/report_for_nc_spm_08_grass7_nc/temporal/t.rast.to.vect/test_to_vect/stdout.html
Similarly, on April 14 (r65052) t.rast.contour failed:
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-04-14-07-00/report_for_nc_spm_08_grass7_nc/temporal/t.rast.contour/test_convert/index.html
Stdout contains some errors regardless of the success state which might be
all right (depends on what is tested):
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-04-14-07-00/report_for_nc_spm_08_grass7_nc/temporal/t.rast.contour/test_convert/stdout.html
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-04-15-07-00/report_for_nc_spm_08_grass7_nc/temporal/t.rast.contour/test_convert/stdout.html
Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150415/d1cf6c21/attachment-0001.html>
