[GRASS-dev] GRASS GIS 7 Addons Manual pages - some mess up in short description
Helmut Kudrnovsky hellik at web.de
Fri Apr 17 12:02:47 PDT 2015
hi,
looking at http://grass.osgeo.org/grass70/manuals/addons/ there seems to be
some mess up in short descriptions:
 r.stream.basins: Calculates surface roughness in a moving-window, as the
orientation of vectors normal to surface planes.
r.stream.channel: Generates a smooth approximation of the input raster and a
discontinuity map.
r.stream.distance: Creates shades from various directions and combines then
into RGB composition.
r.stream.order: A model for shallow landslide susceptibility.
r.stream.segment: Computes Sky-View Factor visualization technique
 v.in.geopaparazzi: Computes the best-fitting ellipse for given vector data.
v.in.gns: Links all OGR layers available in given OGR datasource.
v.in.gps: segment points along a vector line with fixed distances
v.in.ply: Lithospheric flexure: gridded deflections from scattered point
loads
v.in.proj: Calculates DEM derived characteristics of habitats.
v.in.wfs2: Creates metadata based on ISO standard for specified vector map.
v.isochrones: Imports data from Geopaparazzi database.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/GRASS-GIS-7-Addons-Manual-pages-some-mess-up-in-short-description-tp5201877.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
