[GRASS-dev] Limit in g.message? was: Limit in number of "variables" for r.mapcalc?
Nikos Alexandris
nik at nikosalexandris.net
Fri Apr 24 15:09:06 PDT 2015
* Nikos Alexandris <nik at nikosalexandris.net> [2015-04-25 00:51:30 +0300]:
> Hi devs,
> is there a limit in the number of "variables" that r.mapcalc accepts
> within from 'eval'? If yes, how big is it?
> I am trying to feed r.mapcalc's eval with a fairly large number of pixel
> modifiers and, given that the final expression is a valid one, the
> execution ends with:
> debug=1 ended with error
> Process ended with non-zero return code -11. See errors in the (error)
> output.
Problem resolved.
As I tend to use g.message to print out almost everything while testing
scripts, it seems I hit a limit in g.message this time! r.mapcalc has no
problem dealing with the long and complex expression fed to eval.
So the question is, is there a limit in g.message? Number of characters?
I recall a similar question of mine regarding r.support, but I can't
trace it back.
Thanks, Nikos
