[GRASS-dev] [GRASS GIS] #2663: Add test for r.watershed module
trac at osgeo.org
Sun Apr 26 21:19:09 PDT 2015
Reporter: swendel621 | Owner: wenzeslaus
Type: enhancement | Status: new
Priority: normal | Milestone: 7.1.0
Component: Tests | Version: unspecified
Resolution: | Keywords: patch, r.watershed
CPU: Unspecified | Platform: Unspecified
Changes (by wenzeslaus):
* owner: grass-dev@… => wenzeslaus
* keywords: => patch, r.watershed
* component: Default => Tests
* milestone: 7.0.1 => 7.1.0
Comment:
I committed the test together with few style-related changes in r65145.
Thanks, Stephanie!
I suggest to close the ticket after the the automated run is successful.
For completeness, I'm attaching file with changes between original and the
version I committed and here are also the steps I used for integrating it
and testing it (GRASS GIS session active):
#!bash
# prepare dir and files
cd raster/r.watershed/
mkdir testsuite
geany r_watershed_test.
# add to svn
cd ..
svn add testsuite
/script/in/addons/tools/module_svn_propset.sh
testsuite/r_watershed_test.py
cd testsuite
# run the test
python r_watershed_test.py
# automatically introduce as much from PEP8 as possible
autopep8 -i r_watershed_test.py
# check the Python style and syntax
pep8 r_watershed_test.py
pylint r_watershed_test.py
# edit the file accordingly
# run the test again
# publish changes
svn st
svn commit -m "r.watershed: ..."
Ticket URL: <http://trac.osgeo.org/grass/ticket/2663#comment:1>
