[GRASS-dev] [GRASS GIS] #2349: CELL raster format: make ZLIB level 3 standard compression instead of RLE
trac at osgeo.org
Tue Apr 28 15:36:33 PDT 2015
Reporter: neteler | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: critical | Milestone: 7.1.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: compression, r.compress, null
CPU: Unspecified | Platform: All
Comment (by neteler):
Replying to [comment:16 glynn]:
> How large are the null files compared to the cell/fcell files?
* With MODIS LST data, the null files are between 1.7 and 7.6 times
larger than the cell files (we store the LST maps in deg C * 100 as
integer to save disk space).
* With 100k random points, the null file is 7.1 times larger than the
fcell map
* With the EU 25m DEM, the null file is way smaller that the derived
aspect map (17% of the DEM fcell file)
> > What about having a "null2" file which is compressed and with index.
If present, fine, otherwise use the uncompressed well known null file
format?
> That's probably not a great deal of work, but as with any such change,
we need to consider the migration strategy. If we just start creating
compressed null files, mapsets will cease to be usable with older
versions.
Right but this could be covered with an addon/new script in G6 and earlier
(as v.build does for vector data).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2349#comment:17>
